Minneapolis Moline Tractors Discussion Forum
GE30E HEADS ON 403 ENG.
Turtle Gears
01-11-2006 13:08:16
Does anyone know any thing about these heads? My GTB is a 49 model and it was on LP but i changed it to gas. I pull with this tractor and was wandering are these some good heads? or just normal ones. Would apperciate any help thanks T.G.
Andy2
01-12-2006 20:33:34
 Re: GE30E HEADS ON 403 ENG. in reply to Turtle Gears, 01-11-2006 13:08:16
That should be a great all around head for stock pulls. You should be able to run pump gas with no problems. If you go any higher you'll have to burn high octane to prevent detonation. you could pull a plow all day with these heads and have no problems either.
ejr-IA.
01-11-2006 20:07:12
They are a lower comp. head of the many they made.On a 403 that is 7.3 to 1 comp. ratio. thats not the worse though.I use 4206 and 4210 on mine u,ub and G VI.Your pistons can make allot of difference on what heads you have ,flat or steped.
