Minneapolis Moline Tractors Discussion Forum
K4B mag timing
dlp
01-07-2006 10:16:31
When I took my mag apart, I figured that there would be 2 timing marks to easily line up. I guess not, or I'm missing something. How do you time the mag gears together<
kelvin
01-08-2006 13:09:15
 Re: K4B mag timing in reply to dlp, 01-07-2006 10:16:31
Is that K4B similar to a RV4?
I don't know exactly how to time, but you want the magnet to line up across the poles on the coil (or just before this position) at the same time the points open and you want the part that distribuits the fire to the plug wires (A drum affair on the RV4) to line up with one of the plug wire contacts.
dlp
01-08-2006 14:05:00
 Re: K4B mag timing in reply to kelvin, 01-08-2006 13:09:15
There are 2 gears in it. In others I have worked on, one gear will have a mark & the other will have 2 marks. The one mark will mesh between the 2 marks in the other gear. On this one, there is one mark on one & some letters stamped on the fiber gear. I don't know how all this lines up.
