Minneapolis Moline Tractors Discussion Forum
445 coolant problems
Bog
01-05-2006 05:07:33
I just got a 445 utility and it had no thermostat. So the coolant would foam up but the tractor would never get warm. So i put one in it. Now it gets realy hot then blows water out the overflow after about 10 min of running. I was wondering if i am supposed to use a certain type of cap. The one right now is an AC delco that says it is vented at 7lbs. Or do i have something else worng. I tried the termostat turned both ways in the tube and no real differance. Or is there something wrong with my radiator. Is there something i could do to clean out the radiator? Im not sure can you guys give me some kind of hint where to start. Thanks.
Kelvin
01-05-2006 18:04:02
 Re: 445 coolant problems in reply to Bog, 01-05-2006 05:07:33
I tried "Peak" antifreeze in an unpressurized R radiator and it would foam like you said. I haven't changed it, but If do I will use good ol ethylene glycol.
The other guys are right about the hole-needs to be about 1/8" dia. hole in the thermostat and the bulb (usually looks sort of like a '45 caliber bullet case) needs to go toward the head, as it has the temperature sensing spring in it.
I put the 1/8" hole between the lip and the outer dia. of the thermostat, looking from the end.
Rowdy33
01-05-2006 16:39:35
Both our 335 and 445 you can't fill up the radatior completly full. It will go out the overflow tube. So it stays around 3 inches below the top. But it sounds you guys have something that works.
Curt Cooke
01-05-2006 11:02:46
Got to drill that hole and retry!
JK2
01-05-2006 05:54:00
New thermostats usually have too small a bypass hole in the plate or none at all. Since the thermostat is in the hose, some water must bypass the thermostat so it gets warm to open or the results are as you describe.
John
Augie
01-05-2006 09:19:11
 Re: 445 coolant problems in reply to JK2, 01-05-2006 05:54:00
I was having the same problem with my R. Drilled a .125" hole in the thermostat - problem solved.
