Minneapolis Moline Tractors Discussion Forum
SN Dilemma
Evans
12-30-2005 17:53:55
I recently located a MM that my great grandfather owned, and I am going to pick it up tomorrow. It will need a full restoration. My problem is I dont know what year it is. I think it is a 48-50 modelfrom the shape of the nose & headlights. I took the Mode & SN off the block, but all the refferences I find are nothing like the SN I copied. The model says: 3 5/8 X 4CYL EF. The SN: 0175001497. Any help would be greatly appreciated.
John No Mi
12-31-2005 15:32:40
 Re: SN Dilemma in reply to Evans, 12-30-2005 17:53:55
The book I have puts it as a 1950.
Evans
12-31-2005 10:05:46
I FOund the other SN it looks like it says model P, Could be an R. The SN is 001500987
The original BMG
12-30-2005 18:28:29
Evans,
You've posted the serial # for a 1950 EE engine. this was used in the model R tractor. Check the RH side of the trans housing as JLM suggests and you should find the tractor serial # plate.
Brian
JLM
12-30-2005 18:07:59
You are looking at the engine serial number. There is another chassis serial number plate about 3 feet behind the engine plate on the tranny's right side. It is near the belt pulley and probably more to the rear than the belt pulley. MM's have two serial number plates....one for the engine and another for the chassis. Post the chassis SN and we can help you with the year.
