Minneapolis Moline Tractors Discussion Forum
WIDE FRONT END FOR G 955 MM
terry foss
12-28-2005 20:03:40
WILL A FRONT END OFF OF A G 706 STANDARD FIT WITH VERY LITTLE CUTTING AND WELDING
terry foss
12-29-2005 19:38:30
 Re: WIDE FRONT END FOR G 955 MM in reply to terry foss, 12-28-2005 20:03:40
LOOKING TO TAKE STOCK FRONT OFF TO REDUCE WIEGHT, FOR PULLING NEED TO KNOW IF ITS POSSIBLE TO PUT A STANDARD FRONT ON
Kelvin
12-29-2005 18:55:54
Not sure of your question. I'm thinking a G706 should have factory front wheel assist. (G705 was same tractor but had a standard axle).
I'm 99% sure the 706 FWA drop box won't fit as I am sure the transmissions are different, although I can't remember if the G955 transmission is a MM or Oliver design.
Marc Smothers
12-30-2005 07:35:04
 Re: WIDE FRONT END FOR G 955 MM in reply to Kelvin, 12-29-2005 18:55:54
THe G-955 has an Oliver rear end, I believe the same as a 2255. I know the 1355 is a 2255 rear end. THe easy way too tell with 955 is if it has planetaries on the rear end..... Happy NEw Year, Marc
