Minneapolis Moline Tractors Discussion Forum
ubd special
claygourley
12-24-2005 12:38:25
i found a ubd special but it has a gas motor in it instead of a diesel motor or is it possible it come with a gas motor
BMG
12-24-2005 13:15:11
 Re: ubd special in reply to claygourley, 12-24-2005 12:38:25
If the serial number tag says UBD or corresponds to a UBD Special serial number then the engine was probably swapped for a gas unit when it went bad. If you post the gas engine serial # we should be able to tell you when it was made.
Brian
kelvin
12-25-2005 05:42:45
 Re: ubd special in reply to BMG, 12-24-2005 13:15:11
I just want to add that I think all UB'Specials' are very collectable and it would not bother me if it had the 'wrong' engine in it.
