Minneapolis Moline Tractors Discussion Forum
U302 manual steering pump
Daniel Dunmore
12-21-2005 18:37:26
Just bought a U302 super. It steers fine running, but doesn't steer at all shut off. Looking through my IT manual, wondering if I need to replace the pumping element (rotor and stator)? Thanks
Kelvin
12-21-2005 18:57:13
 Re: U302 manual steering pump in reply to Daniel Dunmore, 12-21-2005 18:37:26
Does the steering wheel freewheel when off or does it refuse to turn at all? I have a jetstar3super with similar hydraulics and it does steer with the engine off, it just takes about twice the effort it would if it didn't have power steering.
If the steering wheel freewheels, There is supposed to be a valve that traps fluid in the steering circuit when the engine is off. It might be open. I don't know for sure, but on my jetstar think it is the valve under the fuel tank. The pressure and return lines go to it, then there are other lines to the steering and to the manual motor under the steering wheel. It seems like there would be a similar setup on your U302.
Daniel Dunmore
12-21-2005 19:13:25
 Re: U302 manual steering pump in reply to Kelvin, 12-21-2005 18:57:13
The steering wheel spins without resistance or moving the front wheels when the motor is off.
