Minneapolis Moline Tractors Discussion Forum
Z PTO
sssss
12-17-2005 17:36:07
Will a Z PTO fit a U?
Jim'sMM
12-20-2005 05:00:55
 Re: Z PTO in reply to sssss, 12-17-2005 17:36:07
The PTO unit WILL fit. You only need the longer shaft that is in the rear end.
Kevin Moschenrose
12-20-2005 07:31:06
 Re: Z PTO in reply to Jim'sMM, 12-20-2005 05:00:55
SO then the answer is ONLY HALF CORRECT! Yes you are correct but the outer housing will work only if you have the inner shaft out of the U. Other wise it is useless. Mind set of though shaft PTO's.
Joe Leising
12-19-2005 06:58:11
Do you need a PTO? I have a couple of parts tractors with PTO's that I would sell.
Joe
Kevin Moschenrose
12-17-2005 17:48:32
No it will not!
sssss
12-18-2005 17:09:52
 Re: Z PTO in reply to Kevin Moschenrose, 12-17-2005 17:48:32
Thank You
