Minneapolis Moline Tractors Discussion Forum
6v Battery Charging
bigwally
12-12-2005 15:00:21
Im new to this whole 6v pos ground thing and i am wondering if you can just charge the battery in the tractor by hooking the charger up to the battery, or if this causes problems. Do i have to take the battery out of the tractor to charge it. Thanks
old
12-12-2005 15:34:35
 Re: 6v Battery Charging in reply to bigwally, 12-12-2005 15:00:21
Hook it up just like you would with any thing else. The + ground doesn't make a differance just make sure you do + to + and - to - just like you would if your doing it on your car. To many people over think the + ground.
Leroy
12-12-2005 15:23:01
Just be sure your charger is set for 6 volts and hook + on charger to + on battery and - on charger to - on battery, makes no difference if tractor is + or - ground
