Minneapolis Moline Tractors Discussion Forum
UB standard
paulsn
12-06-2005 16:15:59
Can some one tell me if MM made a UB standard? thanks
LW
12-07-2005 20:08:00
 Re: UB standard in reply to paulsn, 12-06-2005 16:15:59
It probably has the E axle.
BMG
12-07-2005 14:28:58
Check the Canadian parts yards. Lots of ZAS tractors parted out up there. That's where I found mine.
Brian
Alan K
12-06-2005 19:16:45
No, not as far as I know. When they had the UB"s they kept making the UT standards.
Kelvin
12-06-2005 19:47:35
 Re: UB standard in reply to Alan K, 12-06-2005 19:16:45
I don't think MM made any UBs with standard tread.
However, when I was up in Ohio at the Dover show Wendell Everett and his brothers had one in one of their sheds. I don't know if they put standard axles on a UB or put a UB steering column and platform on a standard, as I did not get the serial number.
I always thought it would be cool to put ZAS standard axles on a ZB. It would be high and narrow, though. Anybody got ZAS axles?
Mopower
12-07-2005 05:09:50
 Re: UB standard in reply to Kelvin, 12-06-2005 19:47:35
I have a set coming for my JTU. Also looking for another set for my friends new ZBU. Ought to be very neat!
Paulsn
12-07-2005 14:00:15
 Re: UB standard in reply to Mopower, 12-07-2005 05:09:50
Thanks guys, I seen a UB advertized as a standard,I never seen one or heard of any made.
oliver fan
12-07-2005 14:31:10
 Re: UB standard in reply to Paulsn, 12-07-2005 14:00:15
I will try to answer your question as no one has really done so.
When MM came out with the UB tractors in about 1953 or so, they continued to build a standard U (UTS). They changed the 1953 model from the earlier models by going to 12 volt electrical systems and changing to disk brakes from the old band brakes. They published a brochure on the new UB as well as a brochure on the U (UTS) standard.
Sometime in about 1955 MM built a new UB series called UB Special. Those tractors had a flat grill on the front and most had built in power steering. At that time they changed the U standard (UTS) to a new name.
They started calling them UTS special. They had the same updated as the UB specials. There was a brochure published on the UB special and another published on the UTS special.
I have all 4 brochures and could list them here for your information if you want.
