Minneapolis Moline Tractors Discussion Forum
RTU miss on #1
Rudy J
11-24-2005 12:32:54
Started working on a '49 RTU. New points, distributor cap & plugs. Set timing. Did dry and wet compression test and found 70# & 80# on 2,3,& 4. found 80# and 90# on 1. Switched wires between 1 & 2, #1 misses. Valve clearance is OK. There is a loud pop when reving the engine. Any Ideas?
Andy2
11-27-2005 04:55:11
 Re: RTU miss on #1 in reply to Rudy J, 11-24-2005 12:32:54
It could also be your valvle lash. If it's set too tight it won't let the exhust valve close completely. I think the should be .008 intake and .010 exhaust when the engine is at operating temp.
Kelvin
11-25-2005 04:30:21
I had a U that did that and it had an eroded exhaust valve seat. The popping was the fuel mix exploding in the exhaust manifold.
Rudy J
11-25-2005 12:14:22
 Re: RTU miss on #1 in reply to Kelvin, 11-25-2005 04:30:21
Thanks Guys. I just tried the oil trick and it seemed to help. The valves didn't seem to stick when I pushed them by hand. The exhaust still has some poping but much less than before. The miss has cleared up for now. Thanks again.
BCnT
11-24-2005 13:20:42
somebody told me awhile back if a MM has a miss after its been sitting awhile to pull valve covers and squirt oil on the valve stems...with that pop it sounds like a sticky valve to me.
