Minneapolis Moline Tractors Discussion Forum
MM705 Freeze Plugs
billybunter
11-20-2005 10:20:30
Hi
I beleive their are frost plugs between the cylinder heads in these models. Does the heads and cylinder have to come off to replace. Do these models need either to assist in starting at arround 0 degress or should they start easily with good batteries.
Thanks for now.
D.P.M.
11-21-2005 14:02:20
 Re: MM705 Freeze Plugs in reply to billybunter, 11-20-2005 10:20:30
Yes you will have to pull the heads and jugs to get to those freeze plugs. You will need starting fluid to get a cold M.M. diesel started at 0 degrees,most of mine need it at 50 degrees.
Curt Cooke
11-21-2005 05:26:43
Heads and jugs will have to come off to replace those plugs. Starting, well - I love my minnies but if the temp is below 60 degrees, have some (a lot of) starting fluid on hand.
