Minneapolis Moline Tractors Discussion Forum
How Thick Is A New Brake Lining On RTU?
Geno
11-19-2005 20:33:37
Has Anyone Replaced The Linings Or New Discs On A Model RTU With A 12 Inch Disc? I Need To Know How Thick The Original Or New Old Stock Is? Thanks In Advance
Kelvin
11-20-2005 12:40:19
 Re: How Thick Is A New Brake Lining On RTU? in reply to Geno, 11-19-2005 20:33:37
Before you reinvent the wheel, check with these guys for factory brake linings:
Welter's 417-498-6496
Everetts 740-922-3335
Baucom 1-800-658-2309 (a bit high)
Don Rice 585-243-2617
Since you say its 12" I guess you are working on an early R with a single disk on each side. This was changed to a smaller dia. twin disk arrangement in about 1948. There are some transition models out there with the early wide spline (6 spline?) axles, so be careful.
Geno
11-20-2005 20:35:15
 Re: How Thick Is A New Brake Lining On RTU? in reply to Kelvin, 11-20-2005 12:40:19
Thanks Kelvin For Your Info And Phone Numbers, I Think I Can Get Them Relined In Indy, But Will Check With These Guys First. Your Correct It Is a 1946 R, It Has A Wide 6 Spline Axle. They Have Never Worked Very Well, I Heard They Didn't When New. I have Taken The Brake Assembly Apart And It Is Not Worn And Seems To Work Ok. Adjusted Correctly I Think? Linings Are About 1/4 In. Thick But Hard And Glazed. Any More Info That You Have On These Will Be Appreciated, Thanks Again
