Minneapolis Moline Tractors Discussion Forum
!/4 rod inside oil tube
Keith W from Pa
11-18-2005 11:50:38
The oil tube on my jet star 2 runs up the outside between the heads. Was leaking so I took it off and found this1/4" rod inside it The book I have didn't show this. It must be in there to restrict the oil flow is all I can figure. What do you guys think. Keith
Keith W from Pa
11-18-2005 14:59:11
 Re: 1/4 r od inside oil tube in reply to Keith W from Pa, 11-18-2005 11:50:38
another question. how do you get a good hold of that oil line to screw it into the block tight? Keith
ILL John
11-18-2005 17:32:52
 Re: 1/4 r od inside oil tube in reply to Keith W from Pa, 11-18-2005 14:59:11
The 1/4" rod is to restrict the oil flow, never seen it in a parts book, but all the ones I've had apart have one. I took the "girdle" off the top of the heads to get enough leverage to tighten it.
Keith W from Pa
11-19-2005 04:28:58
 Re: 1/4 r od inside oil tube in reply to ILL John, 11-18-2005 17:32:52
John, thanks for the reply. Keith
