Minneapolis Moline Tractors Discussion Forum
g 705
weeze
11-16-2005 20:33:43
will a 585 diesel fit in a g705 ? thanks jon
Captainhookerus
11-17-2005 16:31:25
 Re: g 705 in reply to weeze, 11-16-2005 20:33:43
No problem just use a 4 cylinder G spacer. Flywheel clutch setup is going to be a problem depending on your desires.
weeze
11-17-2005 18:48:43
 Re: g 705 in reply to Captainhookerus, 11-17-2005 16:31:25
what clutch set up would you recomend my 585 is a late model out of a white 150 thanks
Captainhookerus
11-17-2005 19:03:28
 Re: g 705 in reply to weeze, 11-17-2005 18:48:43
Are you going to have a new transmission input shaft made for a foot clutch? Are you going to use a hand clutch? Anyway you look at it the 2-150 was setup for the Oliver o/u so it won't work.
SWMolines
11-17-2005 05:39:26
The 585 will have a smaller bell-housing bolt pattern than the 705 motor. MM 605 and 800 motors have the same bolt pattern as the 706 bell-housing.
