Minneapolis Moline Tractors Discussion Forum
oil line
KeithW from Pa
11-13-2005 15:18:57
have a jet star2 with an oil line leak. its the line running up the outside between the heads .does it screw into the block and can it be braized.also can it be taken off by taking the valve cover off and just screwing it out? Keith
ILL John
11-13-2005 15:42:30
 Re: oil line in reply to KeithW from Pa, 11-13-2005 15:18:57
Keith, That oil line is 1/8" pipe, it can be screwed out of the crankcase after removing the valve cover and the pieces that attach it to the valve train. you can make a new one, or braze it, it's black pipe just like the gas lines in your house. I had that problem on an engine I took from a UNI and installed in my Big Mo 400. Easy fix for a problem that looks monumental!!
Keith W from Pa
11-13-2005 15:49:37
 Re: oil line in reply to ILL John, 11-13-2005 15:42:30
Ill John, thanks for the reply. Keith
