Minneapolis Moline Tractors Discussion Forum
MM 445 utility loader operation questions
Gregg wills
11-10-2005 10:42:04
just picked up a 455 ut. 1956 runs drives excellent..has factory loader i have questions about the operation of the controls..it seems they all interact with each other..two levers.below the seat rh side by the 3 point lift.anyway to convert to a two stick operation to control the bucket and another to control the liftlike newer tractors? ? and can the pump be modified to produce faster lift? pretty slow,nice old tractor rides like you are on a cushion..gregg
Kelvin
11-11-2005 07:09:50
 Re: MM 445 utility loader operation questions in reply to Gregg wills, 11-10-2005 10:42:04
You may be able to get a larger pump from a 5star, I don't know-better get a second opinion.
I think your tractor is a 445. You are kinda limited to what you can do, on the original system as the pump is plumbed through the rear of the transmission case. Only certain pumps fit and I don't know of any other applications other than MMs.
ILL John
11-11-2005 15:57:12
 Re: MM 445 utility loader operation questions in reply to Kelvin, 11-11-2005 07:09:50
If you can find the engine side mounted pump and crankcase cover off a Brown Mule, it'll have a greater capacity, be constant running, and make the loader independent of the 3 point hitch. Just a thought.
Gregg in ohio
11-13-2005 16:39:31
 Got it c text in reply to ILL John, 11-11-2005 15:57:12
thanks to richard i got the loader working great i just had to add oil in the proper place..id put that loader up against any of em..works like a top and actually lifts stuff..wouldnt before..all i need now is the 445 stainless emblems for the front each side,and a good paint job,and decals,richard i got the seat on looks funky, and painted over the jd green it will do for the winter till i spruce her up..thanks gregg
