Minneapolis Moline Tractors Discussion Forum
O6L-4
Gas-Over-Diesel
11-07-2005 15:17:44
I'm a Farmall guy who's come across a Mnnie-Mo model O6L-4 according to the serial number plate. It has a cab, possibly aftermarket, a power angle plow, more like a dozer blade, and power steering. It looks like it may have been owned by a municipality or an airport or something like that. The plow is definately professional built. Any info would be helpful. Thanks in advance.
BMG
11-07-2005 17:35:08
 Re: O6L-4 in reply to Gas-Over-Diesel, 11-07-2005 15:17:44
I believe you've listed part of the engine model. 206L-4 was a common engine used in the 1960's in several MM tractors. If you post the engine serial # I can tell you what year it was made but you'd be better off looking for another serial # plate on the side of the transmission housing. That plate will have the tractor model and serial #. The cab may make it quite difficult to find the tag on the trans.
Brian
