Minneapolis Moline Tractors Discussion Forum
KEA info needed
dlp
11-04-2005 17:02:32
I just bought a fence row fresh KTA. I haven't brought it home & pulled the head yet, but I am satisfied that nothing short of an atomic explosion will move some of the pistons. Will the pistons, cylinder block, & head off a KEC/KEF work? What other parts will fit?
Paul Blaney
12-04-2005 07:48:15
 Re: KEA info needed in reply to dlp, 11-04-2005 17:02:32
The top end parts from the KEC and KEF should work fine with your KTA. All three models have a single cast head and the same bore and stroke, so I would assume everything up top is identical. Bottom end parts are a different story however. The KEA and KEC have the same bronze backed babbit bearings with shims, but the KEF does not, it has steel precision bearings.
This topic has been discussed before (heads from old U's put on KTA's and visa-versa) so try searching around, you may find more info on the subject.
