Minneapolis Moline Tractors Discussion Forum
10A4207 heads
Don Livingston
11-03-2005 17:49:54
Where is the best place or situation to use 10A4207 heads? By the chart the comp is very high? Are they too high to run on gas or even aviation fuel? Don L.
Mark from OR
11-13-2005 22:56:20
 Re: 10A4207 heads in reply to Don Livingston, 11-03-2005 17:49:54
I have a Set of 07's on a UTU with a stock motor that I use for tractor pulling that works really well. I have won numerous stock pulls with it. I live at 400ft elevations. I have to run straight 110 octane gas ($5.00 a gallon) to keep from pinging and dieseling when shutting it off. I have alot of fun with it. go to the link and down load the movie and watch. Link
Don L.
11-11-2005 04:47:24
Thanks you kind fellows, for your time and input.
You are all scholars and a gentlemen.
Don L.
Harrold Rhodes
11-04-2005 17:12:57
I did get my info from service bulletin from MM. I knew it sounded wrong. Is there any more on it wrong?
Harrold Rhodes
11-04-2005 12:39:25
It would depend on the engine you are using them on.The 4207 is about 9.3 to 1 compression on a 283. 17.6 to 1 on 605. It would be somewhere in between on a 336. Probably close to 11 to 1. Your altitude would also make a difference.
Captainhookerus
11-04-2005 16:20:46
 Re: 10A4207 heads in reply to Harrold Rhodes, 11-04-2005 12:39:25
Harold I have one of those old charts and it is wrong for 07 heads on a 403-605. Correct is 12.6 to 1. Hope this helps.
ILL John
11-03-2005 19:29:47
I've got 4207s on a 336 in a UTS/LP, runs good on LP, can pull 3x14s all day without a problem. Don't know about running them on a gasoline motor.
