Minneapolis Moline Tractors Discussion Forum
206 engine.
Nedd
11-03-2005 14:16:12
Out of my case territory here. Was wondering what the 206 engine out of a uni harvestor fits? I see the 445, jetstar, 3 star and 4 star but was wondering about the u-302 and 335? Harvestor has a good motor and would like to restore a tractor vs. the harvestor. Any help would be appreciated.
JK2
11-04-2005 17:44:25
 Re: 206 engine. in reply to Nedd, 11-03-2005 14:16:12
It depends on whether the Uni 206 engine has a 3 bolt starter or a slip in starter what you can put it in easily.
The 335, 445, most 4 Stars, most JetStars & Big MOs use a slip in starter & the flywheel & ring gear to match. The Jet Star 3s & some late 4 Stars, JetStars & Big MOs use the 3 bolt starter & flywheel & ring gear to match. You can swap the two types freely if you use the correct flywheel, ring gear and starter on these models. I have a 3 bolt engine in my early 4 Star that originally had a slip in starter. I used a Jet Star 3 flywheel, ring gear and starter & it works fine. I also have a 206 from a brown mule in my 335 backhoe that works fine.
The U302 has a flywheel which is different from the others because of the way the PTO drive hub mounts & can only use the three bolt engine with a U302 flywheel & ring gear.
Hope this helps
John
matt lansing
11-03-2005 15:15:10
yes it will fit in Jet star, 445, 335. I have one in a jet star 3. Are you interested in selling the Uni whole??? I would be interested in it if you are.
Thanks Matt Lansing
BCnT
11-03-2005 17:29:29
 Re: 206 engine. in reply to matt lansing, 11-03-2005 15:15:10
i got a good 206 engine if yall make a deal...in Texas if youre interested.
matt Lanisng
11-04-2005 14:16:39
 Re: 206 engine. in reply to BCnT, 11-03-2005 17:29:29
WHat is the price, what is it out of?? Let me know and where are you from in texas
BCnT
11-04-2005 16:26:27
 forgot i had a pic posted in reply to matt Lanisng, 11-04-2005 14:16:39
third party image
got more pix if youre interested
BCnT
11-04-2005 16:23:13
 Re: 206 engine. in reply to matt Lanisng, 11-04-2005 14:16:39
its a stationary engine with clutch and pulley drive...throwout bearing is making some noise but the engine is quiet...its running on propane but its not factory...just the carb was changed.
been advertising it for $750. i'm about halfway between houston and san antone
wide spot in the road called sheridan
