Minneapolis Moline Tractors Discussion Forum
u and utu
Ken C.
11-01-2005 19:03:23
What are the differences between a U and a UTU if any, and what is the bore and stroke and cubic inches of the U. Taking my first moline apart and trying to find out a little about them. Thanks for any help, Ken.
BMG
11-02-2005 16:05:20
 Re: u and utu in reply to Ken C., 11-01-2005 19:03:23
Ken,
A U and UTU are the same tractor. UTU stands for "U" "T"ractor w/ "U"niversal front end (2 wheels closely spaced). Early serial # tags were stamped UTU, UTS, UTN, etc. depending on their front end. Later models were just stamped U. Engines in all U series were 4-1/4" bore x 5" stroke for 283 cubic inches displacement. Engines up through 1947 were mono block type engines meaning all 4 cylinders shared a common cylinder block assy and a one piece head. After 1947 they switched to a split block engine where the cylinders were cast in pairs and there were 2 seperate heads.
Brian
Ken C.
11-02-2005 19:27:38
 Re: u and utu in reply to BMG, 11-02-2005 16:05:20
Thanks for the info, i'm gonna write it down so i don't forget it again. This one has split heads so it must be one of the later models, Thanks again, Ken.
