Minneapolis Moline Tractors Discussion Forum
MM 2 Bottom plow
Jim Lockhart
10-30-2005 18:12:44
Buddy gave me a MM 2 bottom trip,as far as I can tell all it needs is what I would call the "crazy wheel".Does anyone know a good place to get one.This is on rubber and from what I have been able to find out about it,the crazy wheel has a Rubber ring instead of a air up tire.Is this true?
d doughty
10-31-2005 03:31:13
 Re: MM 2 Bottom plow in reply to Jim Lockhart, 10-30-2005 18:12:44
Could be, depending on the year, it came standard with a 2.4x12" steel wheel, or optional 3.5x12" rubber tire and tube. I have two different AF plow manuals. The pictures kinda look like the rubber is solid, but some written discriptions indicate "with tube".
I have two AF 3x14 plows, with one I was given a 10 ply airplane tire. A local tire shop was able to mount it with tube on the rear wheel. It was very difficult because the small tire was so stiff. But it worked great, plowed 5 acres with it last spring.
