Minneapolis Moline Tractors Discussion Forum
wrist pin hole
moli
10-25-2005 06:14:30
Is it possible to run a 6in G crank and stock G rods in a short M5 block bored to 4.81 using custom pistons??I like the longer rod vs the shorter one but want to keep the short block look..I dont think the xtra eigth inch stroke off set grind and short U rods are worth the trade off..Am i right?? all info will help...thanx
Captainhookerus
10-25-2005 07:08:57
 Re: wrist pin hole in reply to moli, 10-25-2005 06:14:30
You will need some pistons with " one inch of compression height". Your decision if it will work.
U engine stroke / 2 + rod length + compression heigth. 5/2+10+2.75=15.25
g engine 6/2+11.25+2.84=17.09
17.09-15.25=1.84
2.84-1.84=1
