Minneapolis Moline Tractors Discussion Forum
camshaft numbers
moli
10-21-2005 07:24:18
I have two cams,one is from a u .number is ke 451g and the other is from a 403 power unit.number is ke451 h..I know thell interchange but is there a diffrence?The u camshaft has all the leters and numbers casted in the shaft but the 403 shaft has the last letter ground off and stamped in( that would be the letter h) any diff...thanx
deadeye
10-21-2005 08:00:47
 Re: camshaft numbers in reply to moli, 10-21-2005 07:24:18
There is no difference only one was cast in a different time frame or year. If you knew the year of the tractors that they came out of, you would probably find that the "H" lettering is the newest one....deadeye
moli
10-21-2005 18:01:44
 Re: camshaft numbers in reply to deadeye, 10-21-2005 08:00:47
The u is a 1949 Im not sure bout the 403 motor,there arent any tags and if there is another place to look i dont know where..I thought the cam and crank gears were supposed to be diffrent(number of teeth)between the two motors but they are not..the hole in the crank gears are also the same...maybe this is a clue? thanx
