Minneapolis Moline Tractors Discussion Forum
MM ZB Info
C Davis
10-18-2005 04:14:34
I currrently purchased a mm ZBN I looked the serial # up it is supposed to be a 1953. does any body know the value restored? any positive or neg info on the zb? when looking for info the zb does not seem to be popular in the MM world are its parts the same as another ? I collect antique tractors I am a farmall man persay we have had nothing but on the farm but i currently have JD AC MM Oliver restored or close to restored in the shed any help would be appreciated
BMG
10-18-2005 05:03:17
 Re: MM ZB Info in reply to C Davis, 10-18-2005 04:14:34
The ZB tractor is essentially the same as the ZA series tractor except the ZB has a raised operator platform and foot clutch. There were much fewer ZB tractors made compared to ZA series. This is typically why you don't see/hear too much about them. Most engine parts are shared with the ZA series tractor and the R series except the R series has different pistons and shorter stroke. The ZBN was the rarest of the ZB series tractors but they were only made in 1954 and 1955 so you might want to double check your serial #. If you post it here we can tell you for sure what you have. It's quite easy to swap front ends on these tractors so you can't rule that out either.
Brian
C Davis
10-20-2005 04:39:04
 Re: MM ZB Info in reply to BMG, 10-18-2005 05:03:17
The tag says ZBN then the serial # i will get it again lost the pare i had it on it is hard to read the actual serial but ZBN is bold but the front end is a normal narrow front with 2 wheels
