Minneapolis Moline Tractors Discussion Forum
hydraulic filter
Keith W in Pa.
10-15-2005 16:38:13
Ihave a Jet Star 2 and am trying to get a hydraulic filter with no luck.I crossed the MM(White) # 10p1851 over to Wix and got# 51828 but it doesn't fit.(too long & o'rings too small)has anyone else had this problem? Keith
Keith W from Pa.
10-17-2005 14:02:49
 Re: hydraulic filter in reply to Keith W in Pa., 10-15-2005 16:38:13
Kelvin,yes the filter is in a canister under the seat. Keith
Kelvin
10-16-2005 11:52:12
Does the tractor have a Tel-O-Flo 3 point? Is the filter in a canister on a bracket up under the seat?
Kelvin
10-17-2005 19:09:56
 Re: hydraulic filter in reply to Kelvin, 10-16-2005 11:52:12
Actually, I was going to give you the NAPA number 1828 if it went on a Tel-O-Flo. Sounds like yours has the wrong part number on the box as I think Wix makes (Or made) NAPA filters.
One thing: The last 2 times I changed these filters the NAPA o-ring didn't fit the canister. I had to stretch it almost to breaking to get it to fit the groove, and this involved removing the canister from the tractor. Probably that o-ring is intended for some other canister assembly.
Then I had to prime the pump inlet tube with a cupful or so of hydraulic oil because it would't pick up oil from the 3-point reservoir by itself.
Keith W from Pa.
10-18-2005 15:43:49
 Re: hydraulic filter in reply to Kelvin, 10-17-2005 19:09:56
Kelvin,thanks for the info.IThe reason I was hesitant about using the filter it was too long (I thought).I made a gasket and put it together.I had to squeeze the filter pretty hard but it went in with no leaks. keith
Keith W from Pa
10-16-2005 08:21:02
Bob, that one won't work either. The old element measures 7.5 long by 3" diam. The wix I got is about 1" too long. Keith
Bob
10-16-2005 13:40:41
 Re: hydraulic filter in reply to Keith W from Pa, 10-16-2005 08:21:02
Keith,
The WIX # 51828 you got must have been mis-boxed.
According to the WIX Numerical Product Listing,
Filter # 51828....
7.779" tall
2.718" Diameter
1.062" Inside Diameter
Bob
10-16-2005 07:18:23
I have a WIX # 51567 filter here, marked "MM Hydraulic", from the days we had a couple of MO's around, but I'm not sure what it fit that we had.
It is listed as 6.991" tall, and 4.530" in diameter. That would be shorter, and quit a bit bigger in diameter than the 51828 you've tried.
I wonder if that # would be a possibility for your application?
