Minneapolis Moline Tractors Discussion Forum
What superseded the ZT and after that?
TWM
10-10-2005 20:15:52
What were the post runners to the ZT through the years of the company? ZA-ZB..... ..
Awhile back I started a thread about what superseded the U. I think I remember Moschy helped me out and we figured that out. Can anyone help me with this?
Thanks
Mopower
10-12-2005 08:21:15
 Re: What superseded the ZT and after that? in reply to TWM, 10-10-2005 20:15:52
The model JT Twin City started it all. The ZT was its styled replacement, however there were some unstyled ZT built in the changeover. 1936???
TWM
10-12-2005 10:36:59
 Re: What superseded the ZT and after that? in reply to Mopower, 10-12-2005 08:21:15
Really?
Any pics?
Mopower
10-12-2005 10:40:50
 Re: What superseded the ZT and after that? in reply to TWM, 10-12-2005 10:36:59
John Grandfield taught me a few things on here about the model J. If you go to the photos posted on this site and type in JT for a search, you will see a few examples. I forget where I saw an early ZT with no styled front end. Maybe it was the collector magazine. I am assembling a JTU with the M-M engine conversion kit since most of them had a Waukesha to start with. Some late ones had a MM ZT engine in them. It was an odd changeover of which I have relatively little information.
TWM
10-12-2005 10:49:15
 Re: What superseded the ZT and after that? in reply to Mopower, 10-12-2005 10:40:50
Isn't an JT and a ZT chassis the same thing? The RE engine drops right in doesn't it?
Mopower
10-12-2005 10:59:08
 Re: What superseded the ZT and after that? in reply to TWM, 10-12-2005 10:49:15
The JT tranny is slightly shorter and something is different on the inspection plate. The RE will bolt in, but the JT has frame rails that attach to the side of the Waukesha engine, cannot fit the RE. There is a bracket that bolts to the front of the RE and to the JT steering. You can also modify the JT frame rails with some M-M supplied directions to fit. I have the files and instructions on my home computer. My JT will be getting a 220 U302 engine in it. How about that from a pile of junk parts?
TWM
10-12-2005 13:52:26
 Re: What superseded the ZT and after that? in reply to Mopower, 10-12-2005 10:59:08
Sounds different!
Wolfgang
10-10-2005 21:34:56
Seems to me it would go:
ZT, ZA, ZB, 445, 4 Star, Jet Star, Jet II,
Kelvin
10-11-2005 09:42:03
 Re: What superseded the ZT and after that? in reply to Wolfgang, 10-10-2005 21:34:56
ZA, ZB, 445, 4star and jetstar concurrently, jetstar2 then jetstar3 and then jetstar3super.
You might actually say that the jetstar replaced the 335 while the 4star replaced the 445 because the jetstar was supposed to be MMs low cost, no frills tractor. Although that wouldn't explain some 335 specials that were built during jetstar production.
TWM
10-12-2005 10:40:40
 Re: What superseded the ZT and after that? in reply to Kelvin, 10-11-2005 09:42:03
Thanks Kelvin!
Anything after the constellation series? I suppose not if the U's and G's were forerunners to the M and newer G-series.
BMG
10-12-2005 14:17:35
 Re: What superseded the ZT and after that? in reply to TWM, 10-12-2005 10:40:40
The Jet Star 3 Super was the end of the line and was made through 1970.
Brian
TWM
10-12-2005 18:04:10
 Re: What superseded the ZT and after that? in reply to BMG, 10-12-2005 14:17:35
Thanks
BMG
10-11-2005 10:23:25
Keep in mind the 4 Star was built only as a row crop tractor. The Jet Star was only built in a utility version. Also, based on engine size there was no replacement for the 335 with its 165 engine.
TWM
10-12-2005 10:37:52
 Re: What superseded the ZT and after that? in reply to BMG, 10-11-2005 10:23:25
Good point.
Chuck S.
10-14-2005 16:11:33
 Re: What superseded the ZT and after that? in reply to TWM, 10-12-2005 10:37:52
The Jet Star replaced the 445 utilty not the 335.The U302 replaced the 4 Star
Ks-farmer
10-10-2005 20:49:13
The 5 star superceded the U and the ZA seriest came after the ZT. Then the 335 for the R and 445 for the ZA.
TWM
10-10-2005 20:58:38
 Re: What superseded the ZT and after that? in reply to Ks-farmer, 10-10-2005 20:49:13
Correct.....
Then what after the 445->->->.....
oliver fan
10-10-2005 21:11:13
 Re: What superseded the ZT and after that? in reply to TWM, 10-10-2005 20:58:38
5 star- m5 -602 -670
445 - 4 star - u302
335 - jet star
