Minneapolis Moline Tractors Discussion Forum
Prairie Gold paint
tylers
10-06-2005 18:51:54
I have a can of martin-senour prairie gold #99l3749 should be gold #2.
It is really orange compared to ppg prairie gold early gold. what can be done to take the orange out.
Have other people had problems with this?
tylers
10-11-2005 20:35:34
 Re: Prairie Gold paint in reply to tylers, 10-06-2005 18:51:54
Thanks for the ideas. I think the paint was mixed wrong at the distributor. They would not take it back at napa where it was purchased.
I finally convinced the painter that it wasn"t the correct shade. I think he contacted the rep. The paint company sent a pint of bright yellow pigment to mix in the orange.
it took about half a pint to get the paint color to match the ppg code mix, which we had half a pint mixed up to compare the colors.
when we were done blending in the yellow we were able to put some of both paints on a paint stick and couldn"t see any different color streaks when the two were put together. I am hoping that all turns out well when it is painted.
when ordering any special paint I would advise anyone to make sure that it can be returned if it is not right.
Thanks for the input.
jossette
10-08-2005 17:08:48
third party image
I am using what they call Federal Yellow in the industrial enamel paints. Looks right to me anyway..
ILL John
10-07-2005 05:42:16
That's the paint I use, if my tractor was in a line of Prairie Gold, it'd look the same color as most. I have a Z, U, 4 Star with that paint. I'd be tempted to take the paint back and see if the guy mixed it right if you think it's the wrong color. John
tylers
10-07-2005 07:49:01
 Re: Prairie Gold paint in reply to ILL John, 10-07-2005 05:42:16
Do you have a picture of yours for comparison, we are going to spray a test panel to see if it looks better that way. What is the difference between prairie gold original and # 2 ?
the #1 mix from ppg on a small spot was closer to what was on the tractor while both ppg and martin-senour #2 mixes looked orange. maybe they will look different on a larger panel.
ILL John
10-07-2005 16:36:39
 Re: Prairie Gold paint in reply to tylers, 10-07-2005 07:49:01
There are pictures of my tactors on this site, tactor photos, type in grandfield, the pictures show the 4 Star and Z much more orange than they are and the UTS shows much more yellow than it is. Don't know how to take a picture that will show the true color. What part of the world are you in? I'm in EXTREME NE Illinois, if all else fails, paint plow wheels or a sign or something to show the true color of the paint when sprayed and dry. If I can help, give me an email grandfieldfarm1 at aol.com use MM as the subject. John
Kelvin
10-09-2005 12:29:03
 Re: Prairie Gold paint in reply to ILL John, 10-07-2005 16:36:39
Its been 10 years since I sprayed any of that paint, but seems to me like It changed shades as it dried and I liked the color a whole lot better 2-3 days later.
Roger Mills
10-10-2005 09:13:36
 Re: Prairie Gold paint in reply to Kelvin, 10-09-2005 12:29:03
Parking lot stripe paint with a gloss hardener matches the underside of my ZA perfectly when dry. The tractor has never been touched since new in about 52. I used an oxidation remover and clear polish to bring out the color. It has a very slight orange tinge to the yellow. I got 5 gallons of the paint from a local asphault company for $10.
