Minneapolis Moline Tractors Discussion Forum
Heads on a UTU LP
Brain
10-04-2005 09:02:23
I recently bought a UTU LP. I think the tractor is one of the last few UTU"s made in 1952. The heads on the tractor are different. One head is part no.10a4213 while the other is a GE30J. The height and depth are the same but the compressions are different. Since the ratios are different, is there cause for concern?
ejr-IA.
10-04-2005 11:49:17
 Re: Heads on a UTU LP in reply to Brain, 10-04-2005 09:02:23
They are the same head just different part no.ge30j was replaced by 4213.
ILL John
10-04-2005 09:44:22
If you're only going to parade, show, etc, no problem, but if you're going to work it, I'd try to get matching heads. Just my 2 cents. John
Harrold Rhodes
10-05-2005 17:33:25
 Re: Heads on a UTU LP in reply to ILL John, 10-04-2005 09:44:22
The 4213 head and the J head are the same compression. No problem running them together. They do use different size spark plugs. 4213 uses 14MM and 30J uses smaller plug. I think 10 MM
