Minneapolis Moline Tractors Discussion Forum
jetstar/jetstar 2 engine
tarbox
09-27-2005 15:59:52
I was looking at a jetstar today that will be in a auction oct.1. It has a hole in the block and I would like to know what other engines would bolt in as a replacement? Thank you.
Mopower
10-03-2005 05:36:33
 Re: jetstar/jetstar 2 engine in reply to tarbox, 09-27-2005 15:59:52
You could use a U302 engine as well. It has a larger cylinder bore, but would bolt in the same as a 206. More horsepower is nice. Haha.
BMG
09-27-2005 16:48:19
tarbox,
There are several engines that may swap into a Jetstar. Those from a 445, 4 Star, or late brown mule uni harvestor just to name a few. These all have the same 206 type engine. Later Jetstar 3's may work but I know their starters bolt on differently. As a side note, the Jetstar 2 was only made in 1963 but is essentially the same as a Jetstar.
Brian
Kelvin
09-28-2005 19:08:10
 Re: jetstar/jetstar 2 engine in reply to BMG, 09-27-2005 16:48:19
Just to add: The parts book for the later 206 engines with 3-bolt starters call for a different ring gear on the flywheel. So if you get one from a junkyard, get the starter and flywheel with ring gear too.
