Minneapolis Moline Tractors Discussion Forum
cracked lp heads
dlp
09-25-2005 14:09:47
I pulled the heads off my UT & found some cracks in the flat gasket surface. One is pretty long, 4-5" between combustion chambers, & some smaller ones on the outside water jacket holes coming in to the head gasket sealing ring. I think they can be welded, the crack does not run down into the head chamber. Are they worth fixing since they are hi-compression?
MS
09-28-2005 13:32:33
 Re: cracked lp heads in reply to dlp, 09-25-2005 14:09:47
I have a pair of heads gone through by an M&M mechanic and also have a pair of jugs honed and ready to slip in. If interested, email me and I will get the #s to you. $200.00 takes all and shipping is on you.
MS
09-28-2005 15:11:06
 Re: cracked lp heads in reply to MS, 09-28-2005 13:32:33
Got home this evening and realized I also have the pistons, brand new rings(still in the boxs)and a rebuilt radiator. Price still stands to you or anyone out there.
ejr-IA
09-26-2005 11:31:11
I agree it would take 200 each to fix the ones you have.Put that towards some good ones.
duner 53
09-25-2005 21:18:02
i have some 4213 that are in great shape for sale?
Kevin Moschenrose
09-25-2005 18:45:27
I think if it was me I would just find different ones and have them checked out. I know there are good ones out there. I would only spend the money to have those repaired as a last option. Having said all that it would be a gamble either way you go but all the same look for better ones as replacements.
