Minneapolis Moline Tractors Discussion Forum
Big Bore for a U Minnie.
UB Nuts
09-22-2005 18:06:43
We are building a 5 9/16 bore, in a dry block with a 6 1/8 inch stroke. The question is with the dry block, I was thinking, I should have a piston cooler installed in the block to help keep the heat down off the pistons. Is this a good choice for a pulling engine? I was going to install an external oil pump on the mag. flange drive, pumping oil from the oil pan and spraying it directly on the pistons in the crankcase. Does anybody out there have any answers or better ideas to make this pulling engine a last a long time?
Mopower
09-23-2005 08:12:38
 Re: Big Bore for a U Minnie. in reply to UB Nuts, 09-22-2005 18:06:43
Bill is right. I have personally seen 5.75 x 7 run for years and never have any major problems and NO LEAKS. You should look into the guy that makes these blocks. It is also possible to make HD800 blocks fit a U for slightly less money.
Bill234
09-22-2005 19:07:36
5.75 x 7 with water in the blocks or you are wasting your time.
