Which MM should I Buy?
Gary
06-29-1998 17:37:37
Wanted a 35+ HP tractor with 3 pt hitch, live PTO, capable of pulling at least 2 - 14" plows. What AC models should I be looking at? I want to stay under $3000. TX Gary
Doug
06-29-1998 21:35:59
 Re: Which MM should I Buy? in reply to Gary, 06-29-1998 17:37:37
: Wanted a 35+ HP tractor with 3 pt hitch, live PTO, capable of pulling at least 2 - 14" plows. What AC models should I be looking at? I want to stay under $3000. TX Gary
Gary,
I am not sure if you are looking for an MM or an AC. If you are looking for an MM I would suggest looking for a 445. They are fairly easy to find and they have 3 point and live pto. They are in the 40-45 HP range. If you want to opt to a slightly larger tractor and a little bit newer, than the 4 Star would be the next choice. They are 45-50 HP and again has 3 point and live PTO. They might be a little bit harder to find but not too much. They both use a 206 cubic inch engine. Good luck.
Doug
