Minneapolis Moline Tractors Discussion Forum
G705 Milky oil
JBf203
09-20-2005 09:29:47
The oil in my g705 turns milky after running it for a number of days. It is LP. Does this mean bad head gasket? How would you check it out?
Daniel Allen
09-21-2005 17:41:53
 Re: G705 Milky oil in reply to JBf203, 09-20-2005 09:29:47
Take the plugs out of the heads and let set for a couple of days the turn it over with out and see if you get a mist out of any of the holes if not then take off the water pump and check the shaft if the bearing gets bad the seal leaks water in to the crankcase it happened on my G1000 VISTA LP.
Kevin Moschenrose
09-20-2005 22:22:32
Welter"s stated one time it could even be something as simple as a plugged water pump weep hole. I remember reading it in the PGR mag.
Ks-farmer
09-20-2005 19:56:10
I have never had any head gaskets go bad just the heads. The 10A4210 heads are know to crack easily.
Daniel Allen
09-20-2005 14:37:46
YOU MIGHT CHECK THE WATER PUMP THE SEAL COULD BE BAD IN IT.
old
09-20-2005 12:04:26
Milky oil means water in the oil from some where. It could be a head gasket and or a cracked block or if it has sleeves a bad seal on the sleeve
