Minneapolis Moline Tractors Discussion Forum
G900 Power steering
Rsimpson
09-14-2005 20:46:57
I have a 1967 or 1968 G900. When the steering fluid gets hot I have to turn the wheel all the time to keep the wheel straight. Is there parts to repair this problem.
James2
09-15-2005 20:38:29
 Re: G900 Power steering in reply to Rsimpson, 09-14-2005 20:46:57
Good luck in getting repair parts. My G950 required too much correction during roading for my liking, so I tried to get a rebuilt kit with a new rotor group. Couldn't get a kit from AGCO, but could get a new steering motor for $2800, and no rebuild kit was available for this new part! Found a NOS steering motor from an old dealer (At work we call then an HMU or hand metering unit) for $1000 and bit the bullet. I'm having a senior moment, but I believe the old hydraulics engineeer at work said the original HMU is a Webster's made in Indiana. Long since bought out by a major hydraulics firm (Eaton or Sundstrand) and have disappeared.
Daniel Allen
09-15-2005 15:03:42
TRY RIVERDALE FARM STORE IN WISCOSIN I GOT ONE FOR MY VISTA FOR ABOUT 250.00 THER NUMBER IS 920 295 3278 GIVE THEM A CALL THEY ARE GREAT GUYS
Dave Ritenburgh
09-15-2005 13:54:41
Sounds to me like the orbital valve (Motor) that the steering wheel attaches to. Probably would have to be rebuilt by a hydraulic shop. The power steering pump usually makes it harder to steer when hot, I think you are saying that it won"t stay centered when hot.
Ks-farmer
09-14-2005 21:22:17
Your local Agco dealer should be able to get a powersteering pump repair kit for you. There are some big trucks that used the Eaton pump too.
Doug Cotton
09-15-2005 07:50:58
 Re: G900 Power steering in reply to Ks-farmer, 09-14-2005 21:22:17
I just went through this on my 900. Take the pump to your local parts store. They can match it up with a new one. It is a big Saginaw Steering pump. I am sure it would be cheaper than going through AGCO. I think I had just around $100 give or take a few dollars.
