Minneapolis Moline Tractors Discussion Forum
Bore size on my UB Special LP
Curt Cooke
09-14-2005 07:05:19
My IT manual indicates the bore on my UBS should be 4 1/4. My operators manual says 4 1/2. My cylinders actually measure 4 3/8. What gives? The real question is - what do I do about pistons and rings. The existing blocks are worn about .010 so my hole size is 4.385. Existing pistons are 5 ring, 4 above the pin and one below. I'm a bit baffled.
Curt
JK2
09-15-2005 05:47:26
 Re: Bore size on my UB Special LP in reply to Curt Cooke, 09-14-2005 07:05:19
Wendell Everett or anyone else that has connections to Hastings should be able to get rings for the M&W pistons. Hastings is pretty good about coming up with rings for most anything.
John
Mopower
09-15-2005 07:03:22
 Re: Bore size on my UB Special LP in reply to JK2, 09-15-2005 05:47:26
I work right down the road from where these ring are made.
Mopower
09-14-2005 12:06:37
Sounds like you have M&W pistons in yours. It should be a 4-1/4 bore. I don't know how much further you can bore, but I would suggest finding some 4.25 blocks to bore to 4.375 or getting some 4.625 blocks to bore. Either way Welters can get you pistons for either block.
Curt Cooke
09-14-2005 12:53:23
 Re: Bore size on my UB Special LP in reply to Mopower, 09-14-2005 12:06:37
Do you know if piston rings for the M & W's are available? I have two other wore out standard blocks that I could bore to the 4 3/8, use the M & W pistons but I would need new rings. Alternatively, I suppose we could bore the existing blocks, sleeve them back to standard and use a set of 4 1/4's I have, assuming rings are available for that.
Mopower
09-14-2005 13:01:07
 Re: Bore size on my UB Special LP in reply to Curt Cooke, 09-14-2005 12:53:23
I would advise against sleeving your MM blocks. Many folks have had bad experiences doing this. Rings are readily available. I think Welters or most good auto parts places could set you up...try your local machine shop. Using the M&W pistons would yield a much better result if they are still in decent shape. Old U blocks are easy to get. Since you are boring to 4.375, the condition of the original bore should not even matter.
Curt Cooke
09-14-2005 13:04:21
 Re: Bore size on my UB Special LP in reply to Mopower, 09-14-2005 13:01:07
Mo, do you know, of course I can check when I get home, are the blocks on a UB the same as the blocks on a UB Special?
Curt
Mopower
09-15-2005 05:20:00
 Re: Bore size on my UB Special LP in reply to Curt Cooke, 09-14-2005 13:04:21
Yes, they are the same, unless they updated the part number during that time. Either way, they will work just fine.
Kevin Moschenrose
09-14-2005 08:36:43
My UTS gas is the same way when I got it 4 3/8" bore with the same piston ring set up. I was told they are M & W pistons and the lower ring is only and extra wiper ring.
