Minneapolis Moline Tractors Discussion Forum
just a question
moli
09-08-2005 19:33:25
Can you use a g crank and rods and still use the short blocks bored to 4.81 or do you need to offset grind crank to fit u rods,I got the welters set up now in my u..Do you actully gain that much more with that little bit of extra stroke vs that longer g rod..just thinkin bout the rod raitio ,piston dwell,rod angle etc...steve
Mopower
09-09-2005 04:53:04
 Re: just a question in reply to moli, 09-08-2005 19:33:25
From what I can tell, a longer rod is a slightly different power (torque) from the less drastic rod angle. I don't know if you can use the big old G rod without one heck of a short piston. The rod might be too long for short blocks. Good question.
