Minneapolis Moline Tractors Discussion Forum
MM R or EE ??
Lars(wi)
09-07-2005 09:16:47
A neighbor has for sale a MM tractor ,side panel says "R" but the tag with model says "EE" I am curious which would be correct?Anything in particular I should be on the lookout for in a used MM tractor? Weather this is an R or an EE is a three-point kit available for this tractor? Would this tractor have enough pto horsepower to operate a trailer generator for a home(no outbuildings or a barn whatsoever) for extended periods of time ? Thanks in advance for any advise given. Lars
kelvin
09-07-2005 09:33:19
 Re: MM R or EE ?? in reply to Lars(wi), 09-07-2005 09:16:47
You are looking at the engine serial number tag. EE is the correct engine for a model R tractor. There should be another tag on the right side of transmission case for the tractor serial number.
Drawbar hp was about 24. you be the judge. Its a gas burner too, so you might want to consider that as well.
