Minneapolis Moline Tractors Discussion Forum
multi fuel manifold and compression
moli
09-05-2005 16:45:03
Just some questions: Has anyone ever ran that purple diesel fuel usin there multi fuel manifold and ge30e heads on a stock mmu?Also, how far can you go up on compression and still run diesel or kero thru the multi fuel manifold with out getting pre ignition problems?Would 4210 heads be too much comp?
Kelvin
09-05-2005 17:15:51
 Re: multi fuel manifold and compression in reply to moli, 09-05-2005 16:45:03
4210 heads would be way too much compression. They are at the limit or just above what you can run with pump gasoline. GE30E heads were correct for gasoline U's.
