Minneapolis Moline Tractors Discussion Forum
m670 oils
Greg Lasher
09-04-2005 06:23:33
I have a gas M670 and I was wondering what type of transmission oil it takes and how you check it? Is it the plugs on the right side of the tractor under the brake pedals? Also - what oil feeds the 3 point is it the transmission oil? If not what is the correct oil and how do you check that?
thanks Greg
Harrold Rhodes
09-04-2005 10:05:10
 Re: m670 oils in reply to Greg Lasher, 09-04-2005 06:23:33
The 670 uses EP 80 or 90 Transmission oil it is checked by the pipe plugs on right side of trans. it should run out of both after the tractor has run a while in high range of the torc. The lift uses type A ATF Should be a pipe with a dipstick cap at right corner of power lift to check it
