Minneapolis Moline Tractors Discussion Forum
ZAU Wheel Hub Help Needed
JKC
08-31-2005 19:17:35
Can anyone offer any advise on how to remove (slide-off) a stuck wheel hub from the rear axle of a ZAU? I have tried lots of heat and plenty of brute force, but cannot seem to budge either of them. Any ideas would be very much appreciated.
Thank you.
Kelvin
09-01-2005 19:06:39
 Re: ZAU Wheel Hub Help Needed in reply to JKC, 08-31-2005 19:17:35
If the tractor is mobile, back off all 4 clamp nuts 1 turn and drive it around some.
Flyrod
09-01-2005 17:27:25
Well for starters is your key still in the axel? I am assuming that it is not so....spray it down with some good penetrating oil "kroil" "blaster". Let it soak as long as you can. You may still have to hit the hub from the backside with a sledgehammer. Also make sure all four bolts are "OFF". This way you should be able to take the fastening plate out of the hub.Get the plate out or off and it should come free.
