Minneapolis Moline Tractors Discussion Forum
Trans oil?
ubnm
08-28-2005 19:32:44
Does the trans. on a UB use the sme oil as the rear end? If not how do you check and fill it? thanks
Kelvin
08-29-2005 18:52:52
 Re: Trans oil? in reply to ubnm, 08-28-2005 19:32:44
yes. check plug is on right side, near where the belt pulley would go. drain plug is at the rear, beside the drawbar.
I think yours will have a 3 corner plate on the transmission cover you can fill through.
I'm pretty sure its supposed to be 140 wt. oil. 90-140 will work. It takes about 12 gallons.
