Minneapolis Moline Tractors Discussion Forum
RTU vs Z radiator
PeteNY
08-28-2005 17:28:29
Guys, Need a new radiator for the RTU, all the catalogs list Z radiators but not Rs...I know alot of parts are interchangeable...is the radiator? Thanks Pete
PeteNY
08-29-2005 05:41:12
 Re: RTU vs Z radiator in reply to PeteNY, 08-28-2005 17:28:29
Thanks guys!
PeteNY
08-30-2005 07:59:01
 Re: RTU vs Z radiator in reply to PeteNY, 08-29-2005 05:41:12
Just an update...it is at the shop being recored...$267.00 well spent! Thanks for the help guys! Pete
ILL John
08-28-2005 19:42:55
Pete, Have you tried your local radiator shop? They can put a new core in your old tanks, they'll measure the old core and order 1 to fit. Don't know what catalogues you're looking at, but ask them, the rad shop, for an estimate.
Kelvin
08-28-2005 18:33:03
Yes and no. It depends. A ZT radiator is almost identical to the RT radiator and will fit the housing. As far as I know, the thermostat housing is different on at least some of the ZTs, but that's about it. A ZA radiator has cast iron tanks, the core bolts between them.
A ZA radiator, tanks, grille and all will bolt to the R front pedestal and you can probably? use the RTU hood, but it changes the look of the tractor.
If you have a radiator, its probably a better idea to get it re-cored.
