Minneapolis Moline Tractors Discussion Forum
445 In a tractor-pull suggestions please.
ROWDY
08-25-2005 13:00:19
Their is a local Dyno tractor-pull this labor Day weakend. It has 14.9-38 over sized tires and, a narrow front. I do plan on modifing the hitch position. Thanks in an advance.
Mopower
08-26-2005 06:24:02
 Re: 445 In a tractor-pull suggestions please. in reply to ROWDY, 08-25-2005 13:00:19
The easiest and cheapest horsepower boost would be U302 blocks bored to 3.875 and U302 intake manifold and carb. Tuned well, you can get 65 h.p. from it.
rick moman
08-25-2005 23:44:16
i just got first place at the dodge co. power show with my 445. it is mostly stock. stock rpms,13.6 38 tires,and a narrow front. it is 4600 lbs. so I pull in the 5000 50 hp class. I beat out 15 other tractors. i pull on a reworked drawbar thats 18in. high and 18in from the center of the axle. I put 400 lbs. on bracket behind the rear axle.On the dyno I put out 44 hp. some of the later 445 snuck out of the factory at 55 hp or so i am told by an old mm dealer.my tractor sat under an apple tree for more then 10 years so after getting it unstuck ,going through the carb and ignition system 44hp is'nt bad for never going into the motor.
ROWDY
08-26-2005 02:16:36
 Re: 445 In a tractor-pull suggestions please. in reply to rick moman, 08-25-2005 23:44:16
Sounds good. I hope I have your luck.
ROWDY
08-26-2005 12:37:59
 Re: 445 In a tractor-pull suggestions please. in reply to ROWDY, 08-26-2005 02:16:36
If I do Get The 302 later in the future....Will it be noticable?
Chuck S.
08-28-2005 16:27:26
 Re: 445 In a tractor-pull suggestions please. in reply to ROWDY, 08-26-2005 12:37:59
The only way anyone can tell is by casting nos.
ROWDY
08-28-2005 17:00:56
 Re: 445 In a tractor-pull suggestions please. in reply to Chuck S., 08-28-2005 16:27:26
So a 302 and a 209 looks the same on the outside? I simply don't wanna cut-up and butcher the tractor up too much. Wanna keep the clasic vintage look. I just found out today Dad already set us up for a tractor show for Sept 24,25.
Thanx again!
Mopower
08-29-2005 07:29:45
 Re: 445 In a tractor-pull suggestions please. in reply to ROWDY, 08-28-2005 17:00:56
Yes, they look the same, except for the casting number.
ROWDY
08-29-2005 14:25:17
 Re: 445 In a tractor-pull suggestions please. in reply to Mopower, 08-29-2005 07:29:45
I'll be on the look-out for one. I know wher a broken down 289 is though!
ROWDY
08-29-2005 14:25:11
Mopower
08-30-2005 05:22:36
 Re: 445 In a tractor-pull suggestions please. in reply to ROWDY, 08-29-2005 14:25:11
What's a 289?
