R w/ 445 engine
MM
06-24-1998 17:31:22
I'm in the early stages of building a 445 powered R. I understand the bellhousing bolts line up. I need help with the tricks to make the clutch work. With double the horsepower it should give quite a ride.
Joe Leising
06-29-1998 07:28:23
 Re: R w/ 445 engine in reply to MM, 06-24-1998 17:31:22
: I'm in the early stages of building a 445 powered R. I understand the bellhousing bolts line up. I need help with the tricks to make the clutch work. With double the horsepower it should give quite a ride.
I can't say for sure, but I would guess that if you use the R flywheel the R clutch and linkage should bolt right up. Make sure the clutch is in good shape. The added power could be quite a strain on it. I have an R with a .125 over ZA motor in it. It has about 40hp and does quite well. I used the R flywheel etc.
hope this helps
