Minneapolis Moline Tractors Discussion Forum
670 bull pinion gear oil leak
herald
08-16-2005 03:43:40
I have a low hour (2,000)670 Super that I can't get to stop oil from leaking thru the plug on the bull pinion gear. I have replaced the "O" ring twice, but it still seaps. What am I doing wrong? Can you use a little thicker "O" ring? I'm using a 50A1783 is what the book calls for. Any ideas would be welcome. Thanks, Harold
JK2
08-16-2005 05:10:50
 Re: 670 bull pinion gear oil leak in reply to herald, 08-16-2005 03:43:40
I've noticed that some new o-rings aren't made very well. Likely, if you use one with a larger cross section, it will be shaved when installed and not seal very well either. I think I would clean all the parts with lacquer thinner & use a little RTV to seal it.
John
