Minneapolis Moline Tractors Discussion Forum
MM R Rear Platform
Jon Feldman
08-15-2005 20:44:08
I recently bought a 44' MM R it has a large rear platform that the draw bar mounts to underneath and also has fenders that mount to it but have never seen these before but are definately made for the tractor,where they an option or aftermarket?Any help would be appreciated!! Thanks! Jon
Molinegb
08-16-2005 18:44:40
 Re: MM R Rear Platform in reply to Jon Feldman, 08-15-2005 20:44:08
My 1939 R CAB AND 1940 RTN have a solid wide platform probably to accomadate the cab. The other 6 of my R's all have the same single center platform with the ones having fenders using the the three piece platform to hold the fenders on. 2 RTE, 1 RTU ,3 RTS all from 1945 to 1950 all the same.
old
08-16-2005 09:17:49
Well that makes it a R with the U option. If its a trike front end then you have a RTU. R is the model. T for trike. U for utility
Kelvin
08-16-2005 18:26:01
 Re: MM R Rear Platform in reply to old, 08-16-2005 09:17:49
As far as I know, all R's had a platform up until about 1950, when MM introduced the 'Hitchor' their 3-point hitch for the tractor.
There were at least 2 styles- '39 and 40 used a 1 piece platform while later tractors had a platform that was sectional, with a center and left and right sections. I parted out a '45 that only had one of the side sections. I have a complete, running '48 RTU and a non-running, nearly complete '49 RTU with the 3-piece platform.
'U' in the model indicates 'Universal' meaning it had a 2 wheel narrow front and It could cultivate as well as plow.
havvey
08-16-2005 04:52:21
yes original, i took mine off to put 3 point hitch on. some had batter on it others under tank i put a hydraulic tank on mine so put battery on the side not original but makes getting to battery easy!
H reiner
08-15-2005 21:26:10
I believe they were an option. The earlier models seem to have them more often. Most of the later R's had a platform that had a center setion and a outer piece could be added on the sides to make the platform wider. As far as I know the old square tank tractors had the wider platform. I have an old parts book that shows the battery box mounted on the platform just inside the left rear fender. and that has the large one piece platform.
