Minneapolis Moline Tractors Discussion Forum
4-Star Super solid front wheels?
Mopower
08-15-2005 10:16:36
I recently purchased a 4-star Super. I noticed the front wheel centers were solid from the bolt holes clear to the the rim. No holes around the edges like the rest of my star series tractors. Are they original? If not, what are they?
John McLucas
08-15-2005 18:55:28
 Re: 4-Star Super solid front wheels? in reply to Mopower, 08-15-2005 10:16:36
Probably JD wheels. I have a JD 630 with solid front wheels. I believe the JD B's are supposed to have solid fronts. The center hole on a JD is slightly smaller that MM, but they can be forced on or filed a little and then they work. If you force them on by pulling them up with the lug nuts, you better hope you are not in the field if they go flat and you have to get them off. If they are JD and forced on, you might want to try removing them in your shop as a test. Use a big hammer. If they come off easily check the center hole and see if someone has filed it out a little.
Check out this photo of a 630 on this site.
John in Georgia
Link
Kevin Moschenrose
08-15-2005 22:03:06
 Re: 4-Star Super solid front wheels? in reply to John McLucas, 08-15-2005 18:55:28
Case also ran some of them on their tractors as well. I am thinking the SC or the CC model tractors. They where heavy too I am guessing to add a little more weight to the front end.
