Minneapolis Moline Tractors Discussion Forum
DUMB?
D.R.W.
08-13-2005 20:16:30
I have a 1953 UBU and can not find the timing mark.All I find is three hles.Any help?
sms
08-15-2005 03:57:23
 Re: DUMB? in reply to D.R.W., 08-13-2005 20:16:30
The timing mark can be hard to see, it takes me awhile to find mine every time. I would mark it with paint to make it easier next time. I believe it is on the outside of flywheel as stated. good luck
Kelvin
08-14-2005 13:07:38
Are you looking on the flywheel? Just about every MM I have seen does have timing marks on the flywheel. I don't have a UB, but on a U they can be seen when I remove the clutch hand hole cover on the left side of the bell housing. And on a U the bell housing casting has a point cast into it for a pointer.
D.R.W.
08-14-2005 13:28:46
 Re: DUMB? in reply to Kelvin, 08-14-2005 13:07:38
Yes I'm looking at the flywheel.I took the cover off the left side.I have turned the flywheel and only find three holes drilled in it to balance it.
BCG
08-14-2005 17:12:31
 Re: DUMB? in reply to D.R.W., 08-14-2005 13:28:46
It's been a while but I think a UB is actualy on the backside of the flywheel. Just around the corner. From what I remember it was had to find.
Ben
Kelvin
08-15-2005 09:21:27
 Re: DUMB? in reply to BCG, 08-14-2005 17:12:31
Remove the front spark plug, hold your finger over the hole and crank it around until it blows air out the hole. You're trying to put the crank on top Dead Center, where the timing mark should be seen at the inspection cover.
If I recall correctly, it is possible to put the flywheel on in 6 different positons, so if the mark is not there, it could be anywhere around the flywheel.
